# Using Connman from inside a container?
**URL:** <https://forums.balena.io/t/using-connman-from-inside-a-container/229835>\
**Tags:** bluetooth, wifi, network\
**Created:** [December 29, 2020, 4:55pm UTC](https://forums.balena.io/t/using-connman-from-inside-a-container/229835 "2020-12-29T16:55:31Z")\
**Showing post:** 36
**Author:** ![mpous](https://sea2.discourse-cdn.com/balena/user_avatar/forums.balena.io/mpous/32/4742_2.png) [@mpous](https://forums.balena.io/u/mpous)\
**Post date:** [December 30, 2020, 12:51pm UTC](https://forums.balena.io/t/using-connman-from-inside-a-container/229835/36 "2020-12-30T12:51:28Z")
Yes! it’s not the best situation! if we try to disconnect the balena Network Manager. Did you try this? [Turn off Bluetooth and WiFi on a running device](https://forums.balena.io/t/turn-off-bluetooth-and-wifi-on-a-running-device/5268/5)
_[View the full topic](https://forums.balena.io/t/using-connman-from-inside-a-container/229835)._
