Hey guys, I’m new here and not sure if this is the right place to post it.
I have found this project and liked it a lot, so I tried to replicate it at home:
Problem is that I want to use FaceTime from Apple, because family are using Apple devices so it is easier for us to build a FaceTime call. Also since the last iOS version, we are able to generate a link to access from external devices, so I thought I could join from the Chromium browser on the RPi.
Problem I am facing is that Apple gives me a link like this one:
ttps://facetime.apple.com/join#v=1&p=5LCcNXFzEiyz0EFXC6m96A&k=1bbaqF66QDIv_JJ1gJ5fIxHFQ4BN-rHBBsXoXCeJvLe
When I put this value into the “KIOSK” Device value, when the OS parses the URL, it ended shorten it on every ‘&’ character, so I am not able to join the call.
This is an example of the log I am getting:
kiosk 2022/02/08 09:54:57 Launch page with desiredURL = ‘FaceTime’. Slack: false
As you can see, the URL was cut after v=1 and next character will be an ‘&’.
I have tried to modify the link and remove the v=1 section, so I put this link into the variable
ttps://facetime.apple.com/join#p=5LCcNXFzPeyz0EHXC6g96A&k=1bbaqF66QDIv_JJ1gJ5fIxHFQ4BN-rHBBsAaXCeJvLe
And again the URL gets cut, in this case after the first ‘&’ character.
kiosk 2022/02/08 09:56:39 Running ‘/home/chromium/launch.sh FaceTime’
It is there any way to avoid this behavior or to ‘escape’ the & character to get it set into the URL correctly?
Thanks! And many thanks for this project, if I get this to work, it would be amazing
