Unable to login to openbalena instance
Hello!
Glad to hear that you are enjoying open-balena.
if you are unsure whether your CNAME record have been set-up correctly, run the following commands from the computer where you are trying to log in.
dig mydomain.org
and
dig api.mydomain.org
if dig api.mydomain.org has no ;; ANSWER SECTION: then the problem relies on your DNS configuration
Remember that CNAME record changes can take up to 72 hours to go into effect.
feel free to post back the output of the dig commands so that we can help you further
