# Unable to get Pi-hole working when following etcher-featured project
**URL:** <https://forums.balena.io/t/unable-to-get-pi-hole-working-when-following-etcher-featured-project/7327>\
**Tags:** raspberrypi3\
**Created:** [May 5, 2019, 4:50pm UTC](https://forums.balena.io/t/unable-to-get-pi-hole-working-when-following-etcher-featured-project/7327 "2019-05-05T16:50:22Z")\
**Showing post:** 9
**Author:** ![chrisys](https://sea2.discourse-cdn.com/balena/user_avatar/forums.balena.io/chrisys/32/1731_2.png) [@chrisys](https://forums.balena.io/u/chrisys)\
**Post date:** [May 6, 2019, 6:45pm UTC](https://forums.balena.io/t/unable-to-get-pi-hole-working-when-following-etcher-featured-project/7327/9 "2019-05-06T18:45:13Z")
OK @jezmck, if you remove your `DNS1` and `DNS2` entries and reboot your device, Pi-hole is going to start working. Right now it’s dependent on `dnscrypt-proxy` to start `pihole`; although the service says running, the internal services aren’t, which is why you can’t get to the web interface.
`dnscrypt-proxy` is failing to start because of [this](https://github.com/balena-io/balena-supervisor/issues/970) bug in the balena supervisor, but if you disable the DNS variables as mentioned above, Pi-hole will still work without it until the fix is deployed. You can also fully comment out the `dnscrypt-proxy` block within `docker-compose.yml` to just remove it for now.
Thanks for posting about the issue; I will update the guide/docs in whatever way we can so that other users aren’t caught by this.
Edit: as an alternative workaround, you can use balenaOS version v2.31.5 when adding your device to the application, which isn’t affected by the issue mentioned above and should work fine out of the box.
_[View the full topic](https://forums.balena.io/t/unable-to-get-pi-hole-working-when-following-etcher-featured-project/7327)._
