Hi @limpro, some questions to understand better:
- At what stage of the provisioning process does the error happen?
- What’s the error that you see when it fails?
For your second question, I’m not sure what you refer to with that issue, but you should be able to use the shm_size property as documented here along with the other listed properties. If they’re not listed, they’re most likely not available yet
