I’m attempting to build a web application at consumes the balena api, however it seems the SDK assumes it has write access to the disk.
Is there a way to disable writing to disk?
2020-03-21T14:56:45.323Z undefined ERROR Error: ENOENT: no such file or directory, mkdir '/home/sbx_user1051/.balena'
at Object.mkdirSync (fs.js:823:3)
at LocalStorage._init (/var/task/node_modules/node-localstorage/LocalStorage.js:156:14)
at new LocalStorage (/var/task/node_modules/node-localstorage/LocalStorage.js:121:12)
at createStorage (/var/task/node_modules/balena-settings-storage/build/local-storage.js:97:16)
at getStorage (/var/task/node_modules/balena-settings-storage/build/storage.js:39:24)
at new BalenaAuth (/var/task/node_modules/balena-auth/build/auth.js:191:24)
at getSdk (/var/task/node_modules/balena-sdk/build/balena.js:102:10)
at Object.<anonymous> (/var/task/api/_setup.js:2:23)
at Module._compile (internal/modules/cjs/loader.js:955:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:991:10)
at Module.load (internal/modules/cjs/loader.js:811:32)
at Function.Module._load (internal/modules/cjs/loader.js:723:14)
at Module.require (internal/modules/cjs/loader.js:848:19)
at require (internal/modules/cjs/helpers.js:74:18)
at Object.<anonymous> (/var/task/api/device/index.js:2:1)
at Module._compile (internal/modules/cjs/loader.js:955:30) {
errno: -2,
syscall: 'mkdir',
code: 'ENOENT',
path: '/home/sbx_user1051/.balena'
RequestId: 3341e0b6-3e99-4faf-91cb-d4083f2dfa39 Error: Runtime exited with error: exit status 1
Runtime.ExitError
