Hi!
I’m trying to compile and run this i2c example with the artik 710 to get the battery power level. However I’m unable to get the code to compile because the Artik SDKs are not able to be included.
* Copyright 2017 Samsung Electronics All Rights Reserved.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing,
* software distributed under the License is distributed on an
* "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND,
* either express or implied. See the License for the specific
* language governing permissions and limitations under the License.
#include <stdio.h>
This file has been truncated. show original
Any ideas how to get this example running?
