rosettaathome : power mgmt fails on pi 4
16.04.20 17:44:52 (+0100) power-management The power management service is disabled for this device type.
balena logs ce6c3e9215c4
Exiting …
Exiting …
Hey thanks for trying out the project. Power management is disabled for Raspberry Pi 4, it’s only meant to disable the switch that suspends computers/laptops when the lid is closed, so it’s only relevant for those device types.
BUT couldnt YOU disable/replace POWER containers on ARM with $ pwd > /dev/null on ARM nodes using DOCKER.TEMPLATE and %%BALENAARCH%% instead of having FAILING containers ?
