# Resolve "The command '/bin/sh -c apk update && apk add jq' returned a non-zero code: 1"
**URL:** <https://forums.balena.io/t/resolve-the-command-bin-sh-c-apk-update-apk-add-jq-returned-a-non-zero-code-1/21118>\
**Created:** [July 18, 2019, 4:28pm UTC](https://forums.balena.io/t/resolve-the-command-bin-sh-c-apk-update-apk-add-jq-returned-a-non-zero-code-1/21118 "2019-07-18T16:28:08Z")\
**Showing post:** 19
**Author:** ![xginn8](https://avatars.discourse-cdn.com/v4/letter/x/8baadc/32.png) [@xginn8](https://forums.balena.io/u/xginn8)\
**Post date:** [July 18, 2019, 7:06pm UTC](https://forums.balena.io/t/resolve-the-command-bin-sh-c-apk-update-apk-add-jq-returned-a-non-zero-code-1/21118/19 "2019-07-18T19:06:00Z")
Hi @agaurav,
I have confirmed this issue locally and tracked it down to some changes released in 11.7.0. If you can downgrade your CLI to 11.6.1, you should be able to build successfully. I have opened [an issue](https://github.com/balena-io/balena-cli/issues/1355) for it as well and we will let you know once it has been fixed.
Thank you for reporting this issue!
_[View the full topic](https://forums.balena.io/t/resolve-the-command-bin-sh-c-apk-update-apk-add-jq-returned-a-non-zero-code-1/21118)._
