Hello resin team,
we would like to use a thermal printer in a multi-container environment with file mode printing. However /dev/usb/lpX is not present on the host os.
dmesg output when unplugging, then replugging the usb device:
The device also disappears, then reappears when listing usb devices with lsusb.
When listing loadable kernel modules, usblp is not present:
find /lib/modules/$(uname -r) -type f -name '*.ko' | grep usblp
Could you please add usblp module in a later version of ResinOS,
or can you suggest any other way to print into file?
Thank you very much in advance!
- host OS version: Resin OS 2.12.7+rev2
- device type: Intel NUC
- printer: CUST_PCTG2460-U-A
