# Raspberry-Pi Wifi Access-point
**URL:** <https://forums.balena.io/t/raspberry-pi-wifi-access-point/1255>\
**Tags:** access-point, wifi\
**Created:** [June 17, 2017, 5:12am UTC](https://forums.balena.io/t/raspberry-pi-wifi-access-point/1255 "2017-06-17T05:12:24Z")\
**Showing post:** 5
**Author:** ![josephroberts](https://sea2.discourse-cdn.com/balena/user_avatar/forums.balena.io/josephroberts/32/233_2.png) [@josephroberts](https://forums.balena.io/u/josephroberts)\
**Post date:** [June 19, 2017, 8:50am UTC](https://forums.balena.io/t/raspberry-pi-wifi-access-point/1255/5 "2017-06-19T08:50:24Z")
Hi @roop
We use Network Manager in resinOS2.x to manage the devices connections. Network Manager supports both creating access points and automatically bridging the connection between multiple interfaces.
Just drop the below example configuration into a file inside the `/boot/system-connections` directory on the SD card and name it `resin-hotspot`, next use the Network Manager [DBUS API](https://github.com/seveas/python-networkmanager) to enable the connection called `resin-hotspot`.
You will then be able to connect to the hotspot using `resin-hotspot` as both the SSID and password.
As a bonus this hotspot method automatically bridges the connection!
```auto
[connection]
id=resin-hotspot
uuid=36060c57-aebd-4ccf-aba4-ef75121b5f77
type=wifi
autoconnect=false
interface-name=wlan1
permissions=
secondaries=
[wifi]
band=bg
mac-address-blacklist=
mac-address-randomization=0
mode=ap
seen-bssids=
ssid=resin-hotspot
[wifi-security]
group=
key-mgmt=wpa-psk
pairwise=
proto=
psk=resin-hotspot
[ipv4]
dns-search=
method=shared
[ipv6]
addr-gen-mode=stable-privacy
dns-search=
method=auto
_[View the full topic](https://forums.balena.io/t/raspberry-pi-wifi-access-point/1255)._
