I am running a pyglet app on a raspberry pi5 that runs at around 60fps on RaspberryPi OS. However, when I port it to balena cloud, containerized, it runs at about 7-10fps. I am using Xvfb and X11vnc to render the gui.
My current theory is that OpenGL is rendering in software rendering mode:
root@608f2de:/app# glxinfo | grep renderer
GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer, GLX_MESA_swap_control,
GLX_MESA_query_renderer, GLX_OML_swap_method, GLX_SGIS_multisample,
Extended renderer info (GLX_MESA_query_renderer):
OpenGL renderer string: llvmpipe (LLVM 15.0.6, 128 bits)
I have the following configuration settings
Force HDMI hotplug: true
RESIN_HOST_CONFIG_gpu_mem=512
RESIN_HOST_CONFIG_dtoverlay=“vc4-kms-v3d”
RESIN_HOST_CONFIG_dtparam=“audio=on”,“i2c_arm=on”,“spi=on”,“audio=on”
application:
build: application/
container_name: application_app
privileged: true
depends_on:
- mongodb-seed
network_mode: 'host'
environment:
- MONGO_URI=mongodb://localhost:27017
- UDEV=1
- DISPLAY=:99
- LIBGL_ALWAYS_SOFTWARE=0 # Ensure hardware rendering is preferred
- MESA_LOADER_DRIVER_OVERRIDE=v3d
- DRI_PRIME=1
cap_add:
- "SYS_RAWIO"
- "SYS_ADMIN"
labels:
io.balena.features.kernel-modules: "1"
io.balena.features.firmware: "1"
io.balena.features.supervisor-api: "1"
devices:
- "/dev/dri:/dev/dri" # Direct Rendering Infrastructure (GPU access)
- "/dev/vcsm:/dev/vcsm" # Broadcom GPU memory interface (if applicable)
- "/dev/gpiomem:/dev/gpiomem"
- "/dev/spidev0.0:/dev/spidev0.0"
- "/dev/spidev0.1:/dev/spidev0.1"
- "/dev/snd:/dev/snd"
volumes:
- application_media:/data/application-media
- application_config:/data/application-config
restart: unless-stopped
# Use a base image for your device
FROM balenalib/raspberrypi5-debian:bookworm
# Install nece# # Add Bookworm repository and install necessary packages
RUN echo "deb [signed-by=/usr/share/keyrings/raspberrypi-archive-keyring.gpg] http://archive.raspberrypi.org/debian/ bookworm main" > /etc/apt/sources.list.d/raspi.list && \
curl -fsSL https://archive.raspberrypi.org/debian/raspberrypi.gpg.key | gpg --dearmor -o /usr/share/keyrings/raspberrypi-archive-keyring.gpg && \
apt-get update && apt-get install -y --no-install-recommends \
build-essential \
cmake git pkg-config \
#pyglet
libgtk2.0-0 libgdk-pixbuf2.0-0 \
libebur128-dev libtag1-dev libavformat-dev libavcodec-dev libswresample-dev libavutil-dev libfmt-dev libinih-dev \
python3-pip python3-venv python3-dev liblgpio1 \
libgl1-mesa-glx libglu1-mesa \
# Not sure if needed
libgl1-mesa-dri libgles2-mesa libx11-6 mesa-utils mesa-vulkan-drivers\
ffmpeg swig sox libsox3 mediainfo \
xvfb x11vnc xauth \
alsa-utils libasound2 pciutils \
vlc libvlc-dev \
# Ensure /app directory exists
RUN mkdir -p /app
# Set the working directory
WORKDIR /app
# Copy application files
COPY . /app
# Clone and build rsgain
RUN git clone https://github.com/complexlogic/rsgain.git && \
cd rsgain && \
mkdir build && cd build && \
cmake .. -DCMAKE_BUILD_TYPE=Release && make && make install
# Use the virtual environment for the application
ENV VIRTUAL_ENV=/application-venv
ENV PATH="$VIRTUAL_ENV/bin:$PATH"
# Copy only requirements file and create virtual environment
COPY requirements-pi.txt /app/requirements-pi.txt
RUN python3 -m venv $VIRTUAL_ENV && \
. ${VIRTUAL_ENV}/bin/activate && \
pip install -r /app/requirements-pi.txt
# Setup ALSA
RUN echo 'drivers = alsa' > ~/.alsoftrc
COPY application/util/docker/asound.conf /etc/
# Environment variables
ENV DISPLAY=:99
ENV SCREEN=0
ENV RESOLUTION=1920x1080x24
# Expose VNC port
EXPOSE 5900
RUN chmod +x application/util/docker/docker-start.sh
# Set the entrypoint
CMD ["/util/docker/docker-start.sh"]
Any help would be greatly appreciated
