Using PiJuice with an rPi 3B+ running on balenaCloud, I am encountering problems with some of the PiJuice functionality.
Specifically, selecting the temperature sensor ‘NTC’ reports that it works (GetBatteryTempSenseConfig() reports: {‘error’: ‘NO_ERROR’, ‘data’: ‘NTC’}), however, the PiJuice continues to report on-board temperatures, rather than the NTC temperatures.
Additionally, setting a custom battery profile results in an error when accessing the pijuice cli.
Following that, I accessed the cli, and selected battery settings, and got the following error message:
root@de3c342a2714:/# sudo -u pijuice pijuice_cli
Traceback (most recent call last):
File "/usr/bin/pijuice_cli.py", line 2013, in <module>
loop.run()
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 278, in run
self._run()
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 376, in _run
self.event_loop.run()
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 682, in run
self._loop()
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 719, in _loop
self._watch_files[fd]()
File "/usr/lib/python3/dist-packages/urwid/raw_display.py", line 393, in <lambda>
event_loop, callback, self.get_available_raw_input())
File "/usr/lib/python3/dist-packages/urwid/raw_display.py", line 493, in parse_input
callback(processed, processed_codes)
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 403, in _update
self.process_input(keys)
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 503, in process_input
k = self._topmost_widget.keypress(self.screen_size, k)
File "/usr/lib/python3/dist-packages/urwid/container.py", line 592, in keypress
*self.calculate_padding_filler(size, True)), key)
File "/usr/lib/python3/dist-packages/urwid/container.py", line 1587, in keypress
key = self.focus.keypress(tsize, key)
File "/usr/lib/python3/dist-packages/urwid/container.py", line 2269, in keypress
key = w.keypress((mc,) + size[1:], key)
File "/usr/lib/python3/dist-packages/urwid/decoration.py", line 621, in keypress
return self._original_widget.keypress(maxvals, key)
File "/usr/lib/python3/dist-packages/urwid/listbox.py", line 985, in keypress
key = focus_widget.keypress((maxcol,),key)
File "/usr/lib/python3/dist-packages/urwid/wimp.py", line 535, in keypress
self._emit('click')
File "/usr/lib/python3/dist-packages/urwid/widget.py", line 463, in _emit
signals.emit_signal(self, name, self, *args)
File "/usr/lib/python3/dist-packages/urwid/signals.py", line 264, in emit
result |= self._call_callback(callback, user_arg, user_args, args)
File "/usr/lib/python3/dist-packages/urwid/signals.py", line 294, in _call_callback
return bool(callback(*args_to_pass))
File "/usr/bin/pijuice_cli.py", line 1913, in item_chosen
callback()
File "/usr/bin/pijuice_cli.py", line 1009, in __init__
self.refresh()
File "/usr/bin/pijuice_cli.py", line 1129, in refresh
self._read_chemistry()
File "/usr/bin/pijuice_cli.py", line 1187, in _read_chemistry
self.chemistries_idx = self.CHEMISTRY_OPTIONS.index(self.ext_profile_data['chemistry'])
ValueError: 'UNKNOWN' is not in list
I’ve discussed these matters with PiJuice, and they mentioned they haven’t worked with balenaOS/balenaCloud. Could something in my balena setup be causing these problems?
My balena supervisor version is 11.4.10, Host OS is balenaOS 2.50.4+rev1
I have a multi-container setup. The portion of my docker-compose for the relevant container is:
sh_pijuice:
container_name: sh_pijuice
build: ./sh_pijuice
restart: on-failure
privileged: true
devices:
- "/dev/i2c-1:/dev/i2c-1"
volumes:
- "cgroup:/sys/fs/cgroup"
labels:
io.balena.features.supervisor-api: true
io.balena.features.dbus: true
io.balena.features.kernel-modules: true
My dockerfile for this container is:
FROM balenalib/rpi-raspbian:stretch
RUN apt-get update && apt-get install -y --no-install-recommends \
python3 \
dbus \
i2c-tools \
raspi-config \
systemd \
systemd-sysv \
pijuice-base=1.6 \
wget \
&& wget -q -O - http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key | apt-key add - \
&& wget -q -O /etc/apt/sources.list.d/mosquitto-stretch.list http://repo.mosquitto.org/debian/mosquitto-stretch.list \
&& apt-get install -y mosquitto mosquitto-clients \
&& touch boot/config.txt \
&& raspi-config nonint do_i2c 0
ENV DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket
ENV INITSYSTEM=on
ENV UDEV=1
COPY . /.
CMD bash entrypoint.sh
Is there anything in my setup that could be causing the problems I’m experiencing with the PiJuice?
Thanks in advance for any help.
