open-balena-api v0.76.3 sql migrations
Hi
You can use your balenaCloud account to create a dummy application, and then download the image. Once you have done that you can configure the os image you just downloaded using the balena cli that you have configured for OpenBalena with the balena preload command. Read more about preload here - https://www.balena.io/docs/reference/balena-cli/#preload-image
