DB container log:
b_1 | 2020-05-29 01:13:16.729 UTC [31] ERROR: relation “uniq_model_model_type_vocab” already exists
db_1 | 2020-05-29 01:13:16.729 UTC [31] STATEMENT: CREATE UNIQUE INDEX “uniq_model_model_type_vocab” ON “model” (“is of-vocabulary”, “model type”);
db_1 | 2020-05-29 01:13:17.024 UTC [31] ERROR: relation “user-has-public key” does not exist
db_1 | 2020-05-29 01:13:17.024 UTC [31] STATEMENT: ALTER TABLE “application type”
db_1 | ADD COLUMN IF NOT EXISTS “modified at” TIMESTAMP DEFAULT CURRENT_TIMESTAMP NOT NULL;
db_1 | ALTER TABLE “config”
db_1 | ALTER TABLE “service instance”
db_1 | ALTER TABLE “application”
db_1 | ALTER TABLE “application environment variable”
db_1 | ALTER TABLE “application config variable”
db_1 | ALTER TABLE “service”
db_1 | ALTER TABLE “service label”
db_1 | ALTER TABLE “service environment variable”
db_1 | ALTER TABLE “application tag”
db_1 | ALTER TABLE “release”
db_1 | ALTER TABLE “release tag”
db_1 | ALTER TABLE “image”
db_1 | ALTER TABLE “device”
db_1 | ALTER TABLE “device environment variable”
db_1 | ALTER TABLE “device config variable”
db_1 | ALTER TABLE “image install”
db_1 | ALTER TABLE “service install”
db_1 | ALTER TABLE “device service environment variable”
db_1 | ALTER TABLE “device tag”
db_1 | ALTER TABLE “gateway download”
db_1 | ALTER TABLE “image-is part of-release”
db_1 | ALTER TABLE “image label”
db_1 | ALTER TABLE “image environment variable”
db_1 | ALTER TABLE “device type”
db_1 | ALTER TABLE “user-has-public key”
db_1 |
db_1 | 2020-05-29 01:13:17.028 UTC [31] ERROR: current transaction is aborted, commands ignored until end of transaction block
db_1 | 2020-05-29 01:13:17.028 UTC [31] STATEMENT:
db_1 | DELETE FROM “migration lock”
db_1 | WHERE “model name” = $1
