Hallo,
i have installed Screenly OSE with Balena and have this error:
nginx: [emerg] a duplicate default server for 0.0.0.0:80
what can I do?
Robi
Hallo,
what can I do?
Robi
This looks like nginx misconfiguration. Please check the following post for possible cause: https://stackoverflow.com/a/30974115
If that does not work for you can you please provide more details - what is screenplay one and what guide do you use to install it.
Thanks, and sorry for mistake. Screenly OSE
I have downloaded the zip over Balena cloud / Ad new device.
Type RaspberryPi4, alenaOS, Vers. v2.71.3+rev1 with Wifi+Ethernet
Same problem for me with fresh version os screenly OSE, i’m trying with other branches as it seems that the base image changed (before : FROM nginx:1-alpine / now : FROM balenalib/rpi-raspbian:buster apt-get install nginx) where are the apt repositories in your rpi-raspbian:buster image ??
Thank you and have a nice day.
Best regards.
I just attempted to deploy a fresh build from balenaHub, using a Pi4, and it worked fine for me. So that is odd. Perhaps try a fresh build, triggered directly by clicking on “Deploy with balena” from the Screenly OSE tile located here: https://hub.balena.io/
Hello !!
Problem fixed on screenly side
Is this fix also for the Installation with Buster
and
$ bash <(curl -sL https://www.screenly.io/install-ose.sh)
Update!
No. Just tried again, the same problem.
