I’m trying to build our Node server which will use CAN on a RPi 4 via MCP2515 on SPI0 along with a MCP3008 ADC via SPI1.
My server is built using Typescript and I am trying to do a multi-stage build of the server build but I’m having a lot of trouble with missing dependancies when the RUN npm install --production
command is executed. It keeps getting build errors when trying to build the SPI, first is was missing python, then make and now it’s missing g++. I have the feeling I’m going about this the wrong way.
Thoughts,
My docker-compose.yml is below, the can-init
service just brings up the CAN interface.
version: "2.0"
services:
can-init:
build: "./can-init" # use this directory as the build context for the service
network_mode: host # expose host network adaptors to the container directly
cap_add:
- NET_ADMIN # allow container to change network settings
restart: no
environment:
CAN0_BITRATE: 250000
server:
build: "./server" # use this directory as the build context for the service
My Dockerfile for the server is below:
# Build stage
FROM balenalib/raspberrypi4-64-node:12-build as builder
WORKDIR /app
RUN install_packages iproute2 can-utils
COPY . .
RUN npm install
RUN npm run clean
RUN npm run build-server
# Run stage
FROM balenalib/raspberrypi4-64-node:12-run
RUN install_packages iproute2 can-utils python make
WORKDIR /app
COPY --from=builder /app/lib ./lib
COPY package*.json ./
CMD ["node", "-r", "dotenv/config", "./lib/index.js"]
