# Is it possible to setup swap on resin.io / ResinOS?
**URL:** <https://forums.balena.io/t/is-it-possible-to-setup-swap-on-resin-io-resinos/2783>\
**Tags:** pendinguserresponse\
**Created:** [March 22, 2018, 10:49am UTC](https://forums.balena.io/t/is-it-possible-to-setup-swap-on-resin-io-resinos/2783 "2018-03-22T10:49:31Z")\
**Showing post:** 2
**Author:** ![wlisac](https://sea2.discourse-cdn.com/balena/user_avatar/forums.balena.io/wlisac/32/1412_2.png) [@wlisac](https://forums.balena.io/u/wlisac)\
**Post date:** [April 25, 2019, 4:08pm UTC](https://forums.balena.io/t/is-it-possible-to-setup-swap-on-resin-io-resinos/2783/2 "2019-04-25T16:08:02Z")
I’m also wondering if it’s possible to setup a swapfile (or otherwise increase the memory limit).
I have a container that may run out of memory when compiling some larger projects during development in local mode.
I haven’t tried this yet, but it looks related: [Create a swap file](https://forums.balena.io/t/create-a-swap-file/3158/5)
_[View the full topic](https://forums.balena.io/t/is-it-possible-to-setup-swap-on-resin-io-resinos/2783)._
