Hi, allow me to preface this by saying that I am not very experienced in this area, however I have found some resources that may be helpful for you.
- The following doc specifies how to disable and re-enable ipv6: Network Setup on balenaOS - Balena Documentation . Specifically it says you should be able to edit a connection with
nmcli
and runset ipv6.method enable
to enable ipv6 - I see a similar forum thread here: Enable IPv6 in container . According to it, you should be able to create a
daemon.json
inside/etc/docker/
withipv6
enabled and then runsystemctl restart balena
Please let us know if either of these solutions work for you.
