I am trying to build a LoraServer on a Raspberry Pi 3 with Stretch using resin.io but i cannot install postgresql and I don’t understand why.
To install it I simply use:
RUN apt-get update && apt-get install -y --no-install-recommends postgresql (also tried with postgresql-9.6) postgresql-client postgresql-contrib && rm -rf /var/lib/apt/lists/*
On git push an error is displayed:
[main] Setting up postgresql-client-9.5 (9.5.4-3) …
[main] update-alternatives: using /usr/share/postgresql/9.5/man/man1/psql.1.gz to provide /usr/share/man/man1/psql.1.gz (psql.1.gz) in auto mode
[main] update-alternatives: error: error creating symbolic link ‘/usr/share/man/man7/ABORT.7.gz.dpkg-tmp’: No such file or directory
[main] dpkg: error processing package postgresql-client-9.5 (–configure):
[main] subprocess installed post-installation script returned error exit status 2
[main] dpkg: dependency problems prevent configuration of postgresql-9.5:
[main] postgresql-9.5 depends on postgresql-client-9.5; however:
[main] Package postgresql-client-9.5 is not configured yet.
[main] dpkg: error processing package postgresql-9.5 (–configure):
[main] dependency problems - leaving unconfigured
Which ends up with this message:
[main] Errors were encountered while processing:
[main] postgresql-client-9.5
[main] postgresql-contrib-9.5
[main] E: Sub-process /usr/bin/dpkg returned an error code (1)
And finishes with : [Error] Not deploying release.
Did anyone else had this problem ? How can it be fixed ?
Best regards,
becklo
