hello
I installed on my application the" balena node red" ,
https://github.com/balenalabs/balena-node-red.
I would like to install another package in my application such as FEH, OMXPLAYER, how can I do that?
thanks
hello
thanks
Hey Denis,
To do that, you have to modify the docker-compose.yaml
file and add more services in there. In essence, you define services in this file and each service runs inside a container. You can read more about multiple containers here:
Docs: https://www.balena.io/docs/learn/develop/multicontainer/
Masterclass: https://www.balena.io/docs/learn/more/masterclasses/services-masterclass/
whaoua … have you a concrete example, I’m starting and I don’t understand everything
if I understood correctly, it is necessary to create a container for each package
if i want to install the omxplayer package, you must create an omwplayer container which will be visible later in the services
Hey
So, I would say that is best to go over the documentation for docker-compose in general https://docs.docker.com/compose/gettingstarted/
The idea is that in the docker-compose file you define a set of services, each service being a container with an image. The image can be either fetched from a docker registry, or built based on a Dockerfile. As you say, omxplayer will be a container and you have to either build the container (by creating the appropriate Dockerfile) or find a docker image on docker-hub, like this one: https://hub.docker.com/r/linkerlab/rpi-omxplayer/ (only for Raspberry)
In order to understand containers, think it like an oven when you can bake a fish and a cake at the same time and when you take them out, each one will smell and taste wonderful, without one spoiling the other.
Cheers!
I’m sorry, I understood the principle but I don’t see how to do it at all … I don’t understand the way to do it …
I do not wish to make an application with omxplayer but I wish to use omxplayer through node red …
Hi, you would do this in your Dockerfile:
RUN install_packages <your package>
