@acostach @mpous
Hey,
It didn’t help. I followed these steps:
- Flashed Compulab u-boot. Here are the logs:
yosef@Debian:~/Downloads$ uuu -lsusb
uuu (Universal Update Utility) for nxp imx chips -- lib1.4.77
Connected Known USB Devices
Path Chip Pro Vid Pid BcdVersion
1:1 MX865 SDPS: 0x1FC9 0x0146 0x0002
yosef@Debian:~/Downloads$ sudo uuu -v -b emmc flash.bin.d2d4
[sudo] password for yosef:
Build in config:
Pctl Chip Vid Pid BcdVersion
SDPS: MX8QXP 0x1fc9 0x012f [0x0002..0xffff]
SDPS: MX8QM 0x1fc9 0x0129 [0x0002..0xffff]
SDPS: MX8DXL 0x1fc9 0x0147
SDPS: MX28 0x15a2 0x004f
SDPS: MX815 0x1fc9 0x013e
SDPS: MX865 0x1fc9 0x0146
SDPS: MX8ULP 0x1fc9 0x014a
SDPS: MX8ULP 0x1fc9 0x014b
SDP: MX7D 0x15a2 0x0076
SDP: MX6Q 0x15a2 0x0054
SDP: MX6D 0x15a2 0x0061
SDP: MX6SL 0x15a2 0x0063
SDP: MX6SX 0x15a2 0x0071
SDP: MX6UL 0x15a2 0x007d
SDP: MX6ULL 0x15a2 0x0080
SDP: MX6SLL 0x1fc9 0x0128
SDP: MX7ULP 0x1fc9 0x0126
SDP: MXRT106X 0x1fc9 0x0135
SDP: MX8MM 0x1fc9 0x0134
SDP: MX8MQ 0x1fc9 0x012b
SDPU: SPL 0x0525 0xb4a4 [0x0000..0x04ff]
SDPV: SPL1 0x0525 0xb4a4 [0x0500..0x9998]
SDPU: SPL 0x0525 0xb4a4 [0x9999..0x9999]
SDPU: SPL 0x3016 0x1001 [0x0000..0x04ff]
SDPV: SPL1 0x3016 0x1001 [0x0500..0x9998]
FBK: 0x066f 0x9afe
FBK: 0x066f 0x9bff
FB: 0x0525 0xa4a5
FB: 0x18d1 0x0d02
FB: 0x3016 0x0001
Run built-in script:
uuu_version 1.2.39
# @flash.bin.d2d4 | bootloader
# @flash.bin.d2d4 [flash.bin.d2d4] | image burn to emmc, default is the same as bootloader
# This command will be run when i.MX6/7 i.MX8MM, i.MX8MQ
SDP: boot -f flash.bin.d2d4
# This command will be run when ROM support stream mode
# i.MX8QXP, i.MX8QM
SDPS: boot -f flash.bin.d2d4
# These commands will be run when use SPL and will be skipped if no spl
# SDPU will be deprecated. please use SDPV instead of SDPU
SDPU: delay 1000
SDPU: write -f flash.bin.d2d4 -offset 0x57c00
SDPU: jump
# if (SPL support SDPV)
SDPV: delay 1000
SDPV: write -f flash.bin.d2d4 -skipspl
SDPV: jump
FB: ucmd setenv fastboot_dev mmc
FB: ucmd setenv mmcdev ${emmc_dev}
FB: ucmd mmc dev ${emmc_dev}
FB: flash bootloader flash.bin.d2d4
FB: ucmd if env exists emmc_ack; then ; else setenv emmc_ack 0; fi;
FB: ucmd mmc partconf ${emmc_dev} ${emmc_ack} 1 0
FB: Done
Wait for Known USB Device Appear...
New USB Device Attached at 1:1
1:1>Start Cmd:SDPS: boot -f flash.bin.d2d4
99%1:1>Okay (4.794s)
- Wrote the image to the USB stick. Here are the logs:
unzip -p iot-gate-imx8plus_debian-linux_2023-03-20.zip | sudo dd of=/dev/sdb1 bs=1M status=progress conv=fsync
3367960576 bytes (3.4 GB, 3.1 GiB) copied, 643 s, 5.2 MB/s
0+51392 records in
0+51392 records out
3368026112 bytes (3.4 GB, 3.1 GiB) copied, 913.467 s, 3.7 MB/s
- Turned off the device
- Disconnected the PROG cable
- Connected the USB3.0
- Turned on the device
After completing these steps, nothing happened, and the device is stuck.
