I’m running a nodejs application using resion.io.
How can I view the console.log or output of the running application?
Kind regards,
Frederik
Kind regards,
Frederik
Hi Frederik,
To view your logs. Go to your dashboard, select your app and then the device you’re working on. In the device panel there is a tab for logs where you will find all the output of the running application.
Cheers,
Craig
