How to set sysctl on HostOS for entire fleet permanently?
I’m running single container, but that shouldn’t matter, these kernel settings should be available in any of your containers. Here’s my output from inside the container, but I get the same result if I do it on the host OS:
root@b1de590:~# sysctl net.core
net.core.bpf_jit_enable = 1
net.core.bpf_jit_harden = 0
net.core.bpf_jit_kallsyms = 1
net.core.bpf_jit_limit = 132942659584
net.core.busy_poll = 0
net.core.busy_read = 0
net.core.default_qdisc = fq_codel
net.core.dev_weight = 64
net.core.dev_weight_rx_bias = 1
net.core.dev_weight_tx_bias = 1
net.core.devconf_inherit_init_net = 0
net.core.fb_tunnels_only_for_init_net = 0
net.core.flow_limit_cpu_bitmap = 0
net.core.flow_limit_table_len = 4096
net.core.gro_normal_batch = 8
net.core.high_order_alloc_disable = 0
net.core.max_skb_frags = 17
net.core.message_burst = 10
net.core.message_cost = 5
net.core.netdev_budget = 300
net.core.netdev_budget_usecs = 8000
net.core.netdev_max_backlog = 1000
net.core.netdev_rss_key = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
net.core.netdev_tstamp_prequeue = 1
net.core.netdev_unregister_timeout_secs = 10
net.core.optmem_max = 20480
net.core.rmem_default = 212992
net.core.rmem_max = 3000000
net.core.rps_sock_flow_entries = 0
net.core.skb_defer_max = 64
net.core.somaxconn = 4096
net.core.tstamp_allow_data = 1
net.core.txrehash = 1
net.core.warnings = 0
net.core.wmem_default = 212992
net.core.wmem_max = 3000000
net.core.xfrm_acq_expires = 30
net.core.xfrm_aevent_etime = 10
net.core.xfrm_aevent_rseqth = 2
net.core.xfrm_larval_drop = 1
I’m also running privileged. Here’s my docker-compose.yml:
version: '2.1'
networks: {}
volumes:
  resin-data: {}
  udevdata:
    driver: local
    driver_opts:
      o: bind
      type: none
      device: /run/udev/data
  logs:
    driver_opts:
      type: tmpfs
      device: tmpfs
  tmpstorage:
    driver_opts:
      type: tmpfs
      device: tmpfs
services:
  main:
    build:
      context: .
      dockerfile: Dockerfile.arm64
    privileged: true
    tty: true
    environment:
      - 'DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket'
    ports:
      - "22:22"
    expose: [22]
    restart: always
    network_mode: host
    volumes:
      - 'resin-data:/data'
      - 'udevdata:/run/udev/data'
      - 'logs:/tmp/DMXCore100Logs'
      - 'tmpstorage:/tmp/DMXCore100Temp'
    labels:
      io.resin.features.kernel-modules: '1'
      io.resin.features.firmware: '1'
      io.resin.features.dbus: '1'
      io.resin.features.supervisor-api: '1'
      io.resin.features.resin-api: '1'
