# How can I increase the partition size of my containers so I can add to /lib/module?
**URL:** <https://forums.balena.io/t/how-can-i-increase-the-partition-size-of-my-containers-so-i-can-add-to-lib-module/101825>\
**Category:** balenaOS\
**Created:** [April 28, 2020, 8:29pm UTC](https://forums.balena.io/t/how-can-i-increase-the-partition-size-of-my-containers-so-i-can-add-to-lib-module/101825 "2020-04-28T20:29:43Z")\
**Showing post:** 13
**Author:** ![garethtdavies](https://sea2.discourse-cdn.com/balena/user_avatar/forums.balena.io/garethtdavies/32/2669_2.png) [@garethtdavies](https://forums.balena.io/u/garethtdavies)\
**Post date:** [May 5, 2020, 7:28pm UTC](https://forums.balena.io/t/how-can-i-increase-the-partition-size-of-my-containers-so-i-can-add-to-lib-module/101825/13 "2020-05-05T19:28:29Z")
Hi, there is a similar forum thread here [Can not install in-tree kernel module](https://forums.balena.io/t/can-not-install-in-tree-kernel-module/92052/2), which has some additional advice. Can you check that first and let us know if you continue to have issues?
_[View the full topic](https://forums.balena.io/t/how-can-i-increase-the-partition-size-of-my-containers-so-i-can-add-to-lib-module/101825)._
