# Fresh Resin OS 2.14.3+rev1 fails to install container
**URL:** <https://forums.balena.io/t/fresh-resin-os-2-14-3-rev1-fails-to-install-container/3777>\
**Created:** [August 21, 2018, 7:42am UTC](https://forums.balena.io/t/fresh-resin-os-2-14-3-rev1-fails-to-install-container/3777 "2018-08-21T07:42:24Z")\
**Showing post:** 13
**Author:** ![brdrcol](https://sea2.discourse-cdn.com/balena/user_avatar/forums.balena.io/brdrcol/32/1116_2.png) [@brdrcol](https://forums.balena.io/u/brdrcol)\
**Post date:** [August 23, 2018, 2:27pm UTC](https://forums.balena.io/t/fresh-resin-os-2-14-3-rev1-fails-to-install-container/3777/13 "2018-08-23T14:27:38Z")
(Responding to [Failed to download image from registry](https://forums.balena.io/t/failed-to-download-image-from-registry/3794/5?u=brdrcol))
Hi @imrehg,
Previously I converted the QEMU disk to VirtualBox vdi with `qemu-img`, increased the disk size to 8GB and memory to 6000MB and let it download/fail for 7 hours. I can’t run that VM at the moment.
I have started a new device (`a64a7fb0f4d50f882bd2d44d808a94f6`) with plain QEMU on Linux and granted support access. Commands were:
qemu-img resize resin-testappqemu-qemux86-64-2.14.3+rev1-dev-v7.16.6.img +8G
qemu-system-x86_64 -drive file=resin-testappqemu-qemux86-64-2.14.3+rev1-dev-v7.16.6.img,media=disk,cache=none,format=raw -net nic,model=virtio -net user -m 8192 -nographic -machine type=pc,accel=kvm -smp 4 -cpu host
It has done two download/fail iterations so far:
`24.08.18 00:19:08 (+1000) Failed to download image [...] due to 'failed to register layer: Error processing tar file(exit status 1): '`
`24.08.18 00:24:52 (+1000) Failed to download image [...] due to 'failed to register layer: Error processing tar file(signal: killed): '`
_[View the full topic](https://forums.balena.io/t/fresh-resin-os-2-14-3-rev1-fails-to-install-container/3777)._
