I try to flash the Hassio Image to my Verbatim Store n Stay USB3.2, but I fail.
Writing and verifying is ok… but it fails at finishing…
Here is my log…
…gui.js:6038 Verifying 1 device, 100% at 36.40 MB/s (total 36.40 MB/s) eta in 0s with 0 failed devices
gui.js:6038 Verifying 1 device, 100% at 37.00 MB/s (total 37.00 MB/s) eta in 0s with 0 failed devices
gui.js:56886 Mon Feb 14 2022 17:46:58 GMT+0100 (Central European Standard Time) Validation error ({“image”:{“size”:2147483648,“compressedSize”:265172896,“hasMBR”:true,“path”:“https://github.com/home-assistant/operating-system/releases/download/7.4/haos_rpi4-64-7.4.img.xz",“partitions”:[{“offset”:1048576,“size”:33554432,“type”:12,“index”:1},{“offset”:512,“size”:1048064,“type”:238,“index”:2}],“isCompressed”:true,“name”:“c3e52bd1-ea40-4f22-ab37-bf4ed33a64e9”,“isSizeEstimated”:false,“extension”:“xz”},“drives”:[{“size”:62914560000,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive3",“error”:null,“isReadOnly”:false,“displayName”:“F:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive3",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“F:\”}],“description”:"Verbatim STORE N GO USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“ab6a035c-2c65-42c8-a14a-24d999a98d8c”,“flashInstanceUuid”:“ab6a035c-2c65-42c8-a14a-24d999a98d8c”,“sample”:0.1,“applicationSessionUuid”:“d5019fea-0bdb-4be4-8f46-817ce7cece05”,“flashingWorkflowUuid”:“beda0c05-5a6f-4966-83f8-03cc92dd0804”})
gui.js:6038 Verifying 1 device, 100% at 36.20 MB/s (total 36.20 MB/s) eta in 0s with 0 failed devices
gui.js:56886 Finish: 2147483648
gui.js:56886 Terminating IPC server
gui.js:56886 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:56886 Mon Feb 14 2022 17:47:03 GMT+0100 (Central European Standard Time) Done ({“image”:{“size”:2147483648,“compressedSize”:265172896,“hasMBR”:true,“path”:“https://github.com/home-assistant/operating-system/releases/download/7.4/haos_rpi4-64-7.4.img.xz",“partitions”:[{“offset”:1048576,“size”:33554432,“type”:12,“index”:1},{“offset”:512,“size”:1048064,“type”:238,“index”:2}],“isCompressed”:true,“name”:“c3e52bd1-ea40-4f22-ab37-bf4ed33a64e9”,“isSizeEstimated”:false,“extension”:“xz”},“drives”:[{“size”:62914560000,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive3",“error”:null,“isReadOnly”:false,“displayName”:“F:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive3",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“F:\”}],“description”:"Verbatim STORE N GO USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“ab6a035c-2c65-42c8-a14a-24d999a98d8c”,“status”:“finished”,“flashInstanceUuid”:“ab6a035c-2c65-42c8-a14a-24d999a98d8c”,“errors”:[{“name”:“Error”,“description”:“Verbatim STORE N GO USB Device”,“code”:“EVALIDATION”,“device”:"\\.\PhysicalDrive3"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:2147483648,“sourceMetadata”:{“isCompressed”:true,“name”:“c3e52bd1-ea40-4f22-ab37-bf4ed33a64e9”,“size”:2147483648,“compressedSize”:265172896,“isSizeEstimated”:false},“sample”:0.1,“applicationSessionUuid”:“d5019fea-0bdb-4be4-8f46-817ce7cece05”,“flashingWorkflowUuid”:“beda0c05-5a6f-4966-83f8-03cc92dd0804”})
gui.js:56886 Mon Feb 14 2022 17:47:04 GMT+0100 (Central European Standard Time) SafeWebview loaded ({“event”:{“id”:25,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.5.113&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1644857224540.189,“resourceType”:“mainFrame”,“ip”:“46.101.121.244”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“31862”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“br”],“content-length”:[“6200”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Mon, 14 Feb 2022 07:56:03 GMT”],“etag”:["“6deb6afefc9e864767b5d7b0f7d070b1-ssl-df”"],“link”:["</webpack-runtime-93a6158ca2315565647c.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-004503f2df4bb68d43f8.js>; rel=preload; as=script, </50c25a04-a68e3217d6ce65727bd7.js>; rel=preload; as=script, </73ad3401-ecb0d3613fde52e78ca5.js>; rel=preload; as=script, </532a2f07-f1ad28da1825cfcce2c7.js>; rel=preload; as=script, </app-d3f2c796bc2e57a8750f.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-4ae9e03f4545d4f1d61b.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-a12561aebb4c48595dd6.js>; rel=preload; as=script, </c974efff6ac245e04f4a26711b42db767846e0e5-b1b7091203b51af325ff.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-98ac1a1084e1d2a478fa.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],“referrer-policy”:[“strict-origin-when-cross-origin”],“server”:[“Netlify”],“status”:[“200”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“01FVWJ2VXNHZXTF16TZRE4Q2XR”],“x-xss-protection”:[“1; mode=block”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“d5019fea-0bdb-4be4-8f46-817ce7cece05”,“flashingWorkflowUuid”:“beda0c05-5a6f-4966-83f8-03cc92dd0804”})
