Not really. We already change using the command to set the eeprom. We did this with your college in the begin of the week. It did solve to flash the firmware. This is not the case: the firmware is there, the serial is ther, only the “new” compiled firmware isn’t working. Hope it helps
Hi @ricardoosorio, I’m investigating the issue regarding the firmata v3.x not deploying correctly. It appears, as you mention, that the firmware isn’t communicating correctly over the serial interface. I will let you know as soon as I have a fix/solution.
Thanks for your patience,
Alex
It looks like your EEPROM and flashing work as expected. I see that you’ve raised the issue with the new compiled firmware in another forum thread, located here: Vanilla Firmware Build fails to work after flash - #16, where a workaround has been provided while an engineer works on the issue. If there’s any further developments, please visit that thread. Thanks!
Cheers,
Christina
