Failing registering device with balenaos-in-container
The certificate which is in your config.json looks like it’s the one built for openbalena.local which is the default domain used when creating an openBalena instance. I was just confirming that your openBalena instance is somewhere within your LAN since .local domains are resolved via mDNS and this doesn’t propogate through gateways/routers normally.
Hey.
By any chance, did you have luck figuring out the configuration with regards to your openBalena setup?
I am still not completely sure about the question, but yes, I am trying to create a docker container with balenaOs + IntelNuc within my LAN.
I didn’t changed any openBalena setups from the tutorial installation.
But I managed to run an intel-nuc image ( balenaOS 2.46.0+rev1) with the same application on a Virtual Machine
Thanks for the information and we continue to try to improve the experience from openBalena.
Hi. Just to let you know, today we released a new major version of openBalena adding support to the later versions of balenaOS.
Feel free to check it out. However, please note that to take advantage of the full functionality at least balenaOS v2.58.3 is recommended.
