If I downloaded from this https://dashboard.balena-staging.io/ URL will it be integrated with the Balena cloud? Is it possible to download it independently?
Independently means like directly downloading may be using openbalena?
When will it be available for download on this url => https://www.balena.io/os/#download ?
Hi @Sharvin26,
To leave Balena cloud and join a local openBalena server you should use the combination of balena leave and balena join commands as referenced in the CLI docs:
https://www.balena.io/docs/reference/cli/#join-deviceip
The image you need will be available for download at https://www.balena.io/os/#download when it will be released to production.
To transition from staging to production, the images need to be first tested by us.
This testing for BBB devices will soon happen.
Regards!
Thanks for the Response.
@spanceac If I want to move a remote device from BalenaCloud to OpenBalena or vice versa is it possible?
Because balena CLI Documentation - Balena Documentation Here it’s stated that
Use this command to move a local device to an application on another balena server.
So How can I do the same operation for Remote device?
Hi, we release version 2.46.1+rev1 to production so you can take a shot at it
