Error fetching/applying device configuration
Getting the following error when trying to restart app/device:
26.06.17 13:42:40 (+0200) Error fetching/applying device configuration: Error: update "deviceConfig" set "targetValues" = '{"RESIN_DEVICE_RESTART":"7827019849039294"}' - SQLITE_READONLY: attempt to write a readonly database
At the moment the docker container is still running, but network access seems broken.
HOST OS VERSION: Resin OS 1.26.0
SUPERVISOR VERSION: 4.2.4
Hi there,
Iā€™m going to contact you privately to get some more information this.
It seems there was a filesystem corruption issue.
We have fixed your device but perhaps you should consider replacing the SD card of your device in the near future.
Best,
ilias
