Originally published at: https://blog.balena.io/emudhra-ca-compromise-what-balena-customers-should-do-now/
Following the public disclosure of the eMudhra CA compromise, we patched balenaOS, our cloud backend, and developer tooling. Here is the full breakdown of what happened, how our stack protects your fleet, and the three simple steps to update your remote devices and keep your containers secure.
how to update for devices with older BalenaOS versions (like jetson-nano)?
We would strongly encourage you to move to a supported device since this will likely not be the last CVE and there may be no future workarounds for discontinued devices. However, to address the eMudhra compromise on devices that can’t upgrade to a newer balenaOS version, one of our colleagues has published a block that you can test in a lab setting first and see if it will work for your device: GitHub - balena-io-experimental/ca-distrust-block: balena block that distrusts the compromised eMudhra roots in the hostOS CA store on releases before v7 · GitHub
certifi likely should be 2026.10.23 or newer, they did a few more cleanup steps after the .19.
Quite minor compared to the rest and package managers will hopefully pick it up, just since the post is from 3 days after that fix-of-a-fix-of-a-fix.
Cheers for the thorough blogpost, though!
