Hi, in the dashboard when downloading the device image, for Linux this line is given as an example of writing the image onto an SD card:
sudo dd bs=1m if=~/Downloads/<OS-image-download>.img of=/dev/rdiskN
On Linux this won’t work, I think, because the bs
parameter does not accept the “m” suffix (as opposed to OSX where that’s correct). The correct line should be:
sudo dd bs=1M if=~/Downloads/<OS-image-download>.img of=/dev/rdiskN
From man dd
as reference:
N and BYTES may be followed by the following multiplicative suffixes: c
=1, w =2, b =512, kB =1000, K =1024, MB =1000*1000, M =1024*1024, xM =M
GB =1000*1000*1000, G =1024*1024*1024, and so on for T, P, E, Z, Y.
