# Communicating over UART0 with HCI uart BLE dongle (cross post)
**URL:** <https://forums.balena.io/t/communicating-over-uart0-with-hci-uart-ble-dongle-cross-post/193535>\
**Category:** balenaOS\
**Tags:** support, bluetooth, raspberrypi3, serial\
**Created:** [September 25, 2020, 11:24am UTC](https://forums.balena.io/t/communicating-over-uart0-with-hci-uart-ble-dongle-cross-post/193535 "2020-09-25T11:24:59Z")\
**Showing post:** 11
**Author:** ![mdcraver](https://avatars.discourse-cdn.com/v4/letter/m/d9b06d/32.png) [@mdcraver](https://forums.balena.io/u/mdcraver)\
**Post date:** [October 6, 2020, 1:30pm UTC](https://forums.balena.io/t/communicating-over-uart0-with-hci-uart-ble-dongle-cross-post/193535/11 "2020-10-06T13:30:01Z")
I have “miniuart-bt=on” set in the DT overlays, but it doesn’t seem to work.
I wonder if this issue is, at least in part, due to issues in setting GPIO Alternate functions. With that in mind, and referencing [page 102 of the BCM2835 ARM Peripherals documen](https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf#page=102)t
1. For ttyS0 uart, I am assuming it it use TXD0/RXD0, and not TXD1/RXD1.
2. Does the “uart-ctsrts” DT overlay change the alternate functions of the GPIO16/GPIO17 to be CTS/RTS respectively, or do I need to use a script like the following [rpirtscts](https://github.com/deater/uarch-configure/tree/master/rasp-pi-serial) (From [Raspberry Pi 3 Hardware Flow Control](http://www.deater.net/weave/vmwprod/hardware/pi-rts/)
_[View the full topic](https://forums.balena.io/t/communicating-over-uart0-with-hci-uart-ble-dongle-cross-post/193535)._
