I have installed the openBalena server on an AWS EC2 instance and configured the needed domains:
viso.dev
api.viso.dev
s3.viso.dev
vpn.viso.dev
registry.viso.dev
All domains are redirected to the IP address of my EC2 instance.
And of course, I’ve installed the certificate file on my local machine by export NODE_EXTRA_CA_CERTS='/path/to/ca.crt'
command.
But I am getting this error when I try logging in:
pl-extreme@plextreme-UP-WHL01:~$ sudo balena login
_ _
| |__ __ _ | | ____ _ __ __ _
| '_ \ / _` || | / __ \| '_ \ / _` |
| |_) | (_) || || ___/| | | || (_) |
|_.__/ \__,_||_| \____/|_| |_| \__,_|
Logging in to viso.dev
? How would you like to login? Credentials
? Email: balena@viso.ai
? Password: [hidden]
ECONNREFUSED: request to https://api.viso.dev/login_ failed, reason: connect ECONNREFUSED 52.28.104.246:443
variable: "set DEBUG=1" on a Windows command prompt, or "export DEBUG=1"
on Linux or macOS.
https://forums.balena.io
But I swear that 443 port is opened on my EC2 instance:
Any idea?
P.S. I have opened 3218 too after checking this - Necessary ports for open balena?
