I am building Balena OS for Generic x86_64 architecture and getting below error while building.
ERROR: docker-disk-amd64-supervisor-v12.11.16-r0 do_compile: docker-disk: Can’t compile as there is no internet connectivity on this host.
ERROR: docker-disk-amd64-supervisor-v12.11.16-r0 do_compile: Execution of ‘/home/sivashax/Balena/balena-intel/build/tmp/work/genericx86_64_ext-poky-linux/docker-disk/amd64-supervisor-v12.11.16-r0/temp/run.do_compile.19298’ failed with exit code 1:
WARNING: exit code 1 from a shell command.
ERROR: Logfile of failure stored in: /home/sivashax/Balena/balena-intel/build/tmp/work/genericx86_64_ext-poky-linux/docker-disk/amd64-supervisor-v12.11.16-r0/temp/log.do_compile.19298
ERROR: Task (/home/sivashax/Balena/balena-intel/build/…/layers/meta-balena/meta-balena-common/recipes-containers/docker-disk/docker-disk.bb:do_compile) failed with exit code ‘1’
ERROR: balena-supervisor-1.0-r0 do_install: Could not retrieve supervisor image for version v12.11.16
ERROR: balena-supervisor-1.0-r0 do_install: Execution of ‘/home/sivashax/Balena/balena-intel/build/tmp/work/core2-64-poky-linux/balena-supervisor/1.0-r0/temp/run.do_install.19299’ failed with exit code 1:
ERROR: Logfile of failure stored in: /home/sivashax/Balena/balena-intel/build/tmp/work/core2-64-poky-linux/balena-supervisor/1.0-r0/temp/log.do_install.19299
ERROR: Task (/home/sivashax/Balena/balena-intel/build/…/layers/meta-balena/meta-balena-common/recipes-containers/balena-supervisor/balena-supervisor.bb:do_install) failed with exit code ‘1’
NOTE: Tasks Summary: Attempted 3276 tasks of which 3263 didn’t need to be rerun and 2 failed.
I am building this behind proxy configuration and have setup http_proxy, https_proxy in shell. However, still building is failing.
Appreciate support on this.
