I’am working on running Balena on STM32MP. Got it working on SD-card and almost on emmc. It boots once but not twice. After some reboots from the watchdog it works. I guess the watchdog is set to 10 sec. What is taking so long time after first boot?
[ 2.196116] can: broadcast manager protocol (rev 20170425 t)
[ 2.200881] mmcblk1rpmb: mmc1:0001 004GA0 partition 3 512 KiB, chardev (244:0)
[ 2.206552] Key type dns_resolver registered
[ 2.216492] ThumbEE CPU extension supported.
[ 2.227816] Registering SWP/SWPB emulation handler
[ 2.238225] registered taskstats version 1
[ 2.240973] Loading compiled-in X.509 certificates
[ 2.243187] mmcblk1: p1 p2 p3 p4 p5 p6
[ 2.265734] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01 02:02:37 UTC (946692157)
[ 2.273879] usb33: disabling
[ 2.275844] ALSA device list:
[ 2.278787] No soundcards found.
[ 2.291609] usb 1-1: New USB device found, idVendor=0bda, idProduct=b82c, bcdDevice= 2.10
[ 2.297927] Freeing unused kernel memory: 9216K
[ 2.298349] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.310337] usb 1-1: Product: 802.11ac NIC
[ 2.314002] Checked W+X mappings: passed, no W+X pages found
[ 2.314065] usb 1-1: Manufacturer: Realtek
[ 2.319743] Run /init as init process
[ 2.323789] usb 1-1: SerialNumber: 123456
starting version 239
[ 3.270240] random: fast init done
[ 4.194556] zram0: detected capacity change from 0 to 113094656 <— It most often reboot after this message.
[ 13.436701] random: crng init done <— But this time it worked as next step is under 10 sec
[ 14.162740] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
[ 14.225703] EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: (null)
[ 14.899866] EXT4-fs (mmcblk1p3): re-mounted. Opts: (null)
[ 15.312358] systemd[1]: System time before build time, advancing clock.Welcome to balenaOS 2.58.0!
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on udev Control Socket.
[ OK ] Created slice system-resin\x2dinfo.slice.
[ OK ] Reached target Remote File Systems.
[ OK ] Listening on udev Kernel Socket.
