balenasound live input
is it possible to use a live analog input from a soundboard in balenasound to stream it’s audio throughout my local network?
From what I understand you want to connect the output from the soundboard to the input of balenaSound, correct? I asked the balenaSound folks here if it’s possible to use a balenaSound device as a transmitter, but balenaSound currently only supports audio output, no input, through the audio jack.
I haven’t tried it myself but I think your best bet would be to try and connect the soundboard over Bluetooth to balenaSound. Either using your computer as a transmitter or attaching a transmitter device to your soundboard directly.
Ah! Bluetooth. I haven’t thought of that. I might give that a try. Thanks
