Hi guys, I found this strange error
Balena staging is not working from the dashboard or via remote git push
I was working with the staging environment and now it’s not responding.
I thought it was an error with my code or the application, I also tried to create a new app and it does not work either.
Same from git push balena-staging master
[Error] An error occured: It is necessary that each device that should be managed by a release, should be managed by a release that belongs to an application that is public and is not host and has an app name that is equal to "aarch64-supervisor" or "amd64-supervisor" or "armv7hf-supervisor" or "i386-supervisor" or "i386-nlp-supervisor" or "rpi-supervisor".
[Error] Upstream API server/DB error:
